If you're trying to get all the devices in your circuit, then 2 is the most efficient, because it's one change. 3 requires a change for every model, 1 requires a change for every instance. However, if you want different instances to have different temperatures, then 1 is your only option.
For a bug-free simulator, all three should give the same answer.
