Aug 15th, 2024, 6:35pm
How to make a symbol in ADE reference a spectre netlist (Read 4070 times)
mlujan1965
Jun 05th, 2009, 7:57am
Hello
I have a loss model described with a spectre netlist.
I would like to make a symbol to use in ADE that references the
netlist rather than a schematic. How is this done?
Thanks.
Re: How to make a symbol in ADE reference a spectre netlist
Reply #1 - Jun 7th, 2009, 10:40pm
Please try to create a symbol, which must have the same name and pins as that netlist. Then include that netlist in ADE -> Simulation Files ... -> Stimulus File.
I have done successfully with a SPICE OPAMP netlist.
Yawei
Frank Wiedmann
Munich, Germany
Reply #2 - Jun 7th, 2009, 11:29pm
For details regarding the method suggested by Yawei, see http://www.cadence.com/Community/blogs/rf/archive/2009/01/07/tip-of-the-week-how.... For an alternative and possibly simpler method, see http://www.designers-guide.org/Forum/YaBB.pl?num=1191334088.
mlujan1965
Reply #3 - Jun 8th, 2009, 9:56am
Thanks Yawei
I wrote a simple netlist for an RC see below:
simulator lang = spectre
subckt TestRC In Out GND
parameters Rval
R1 (In Out) resistor r=Rval
C1 (Out GND) capacitor c=10p
ends TestRC
I have edited the Base CDF and added Rval as Component Parameter
I keep getting the fllowing spectre error:
I1.R1: parameter 'r' : The parameter 'Rval' is used but not set.
What am I doing wrong?
Also is there a way to get the subckt netlist displayed in the
main netlist?
thanks
Reply #4 - Jul 10th, 2009, 6:36am
You need to add "Rval" as an instParameter in the spectre simulation information section of the CDF, so that it knows it needs to be netlisted for spectre. It sounds as if you have a parameter "r" that is being netlisted (which shouldn't be the case, since your subckt doesn't have "r" as a parameter). So check what parameters are being netlisted in the spectre simulation information part of the CDF.
