You need to add "Rval" as an instParameter in the spectre simulation information section of the CDF, so that it knows it needs to be netlisted for spectre. It sounds as if you have a parameter "r" that is being netlisted (which shouldn't be the case, since your subckt doesn't have "r" as a parameter). So check what parameters are being netlisted in the spectre simulation information part of the CDF.
