Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Aug 15
th
, 2024, 6:57am
Home
Help
Search
Login
Register
PM to admin
Simulators
Circuit Simulators
› How to measure current between draina nd source in eldo
Previous topic
Next topic
How to measure current between draina nd source in eldo (Read 4353 times)
rajivs1001
Belgium
Jun 09
th
, 2009, 2:59pm
Is there any way I could measure the current flowing between source and drain terminal of a transisotr without modifing the netlist ?
-Rajiv
IP Logged
oermens
Re: How to measure current between draina nd source in eldo
Reply #1 -
Jun 9
th
, 2009, 3:19pm
Which simulator are you using? If Spectre in ADE, go Outputs>save all...> and theres an option for terminal currents (userprobe)
my mistake, i guess i didnt read the whole thread title
Last Edit: Jun 10
th
, 2009, 4:28am by oermens
IP Logged
rajivs1001
Belgium
Reply #2 -
Jun 9
th
, 2009, 3:29pm
I was asking about ELDO simulator.
-Rajiv
IP Logged
AnalogDE
Reply #3 -
Jun 9
th
, 2009, 4:59pm
Add the following line to your spice deck:
.PROBE I(Mxx.D) or
.PROBE I(Mxx.S)
where Mxx is the instance name of the MOS you are interested in.
IP Logged
rajivs1001
Belgium
Reply #4 -
Jun 11
th
, 2009, 9:21am
I was under the impression that I(Mxx.D) measures current between Drain and bulk but I verified that my assumption was not correct.
Thanks for the reply.
-Rajiv
IP Logged
Reply #5 -
Jun 12
th
, 2009, 10:26am
Note that I(Mxx.D) includes drain to bulk current, but usually that's smaller than the channel current.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
»» Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
