Jul 17th, 2024, 1:38pm
how to give pulse (Read 3717 times)
raja.cedt
how to give pulse
Jun 21st, 2009, 9:16am
hi,
  can anybody please tell me how to give a pulse with variable frequency in hspice, i know that PWL will work but very lengthy...
Rajasekhar.
Re: how to give pulse
Reply #1 - Jun 21st, 2009, 10:04pm
raja.cedt wrote on Jun 21st, 2009, 9:16am:
can anybody please tell me how to give a pulse with variable frequency in hspice, i know that PWL will work but very lengthy....
I can't understand what you are confusing.
Use pulse() like following.
Quote:
.param Vlow=0.0 Vhigh=3.0
.param fclk=100MHz
.param Tperiod='1/fclk'
.param Tdelay=0.0
.param duty=0.5
.param Trise='Tperiod/20'
.param Tfall='Tperiod/20'
.param Twidth='Tperiod*duty-(Trise+Tfall)/2'
vpulse 1 0 pulse( Vlow Vhigh Tdelay Trise Tfall Twidth Tperiod )
« Last Edit: Jun 22nd, 2009, 12:00am by pancho_hideboo »
raja.cedt
Reply #2 - Jun 22nd, 2009, 1:46am
hi i am sorry, i mean to say that i want some frequency till some time after that i need another frequency..
Rajasekhar.
Reply #3 - Jun 22nd, 2009, 2:20am
raja.cedt wrote on Jun 22nd, 2009, 1:46am:
Create signal sources using Verilog-A.
It is very easy to generate such signals if you use $abstime, @timer() and transition() in Verilog-A.
If frequency variation is continuous, you can use FM-signal source and limitter to generate pulse signal of continuous FM without using Verilog-A model.
As another method, you can use signals based on VCD(Value Change Dump) format data.
This method is also implemented in both Cadence Spectre and Agilent GoldenGate.
http://www.designers-guide.org/Forum/YaBB.pl?num=1207062028/4#4
Currently almost all commercial transient simulator have an ability of generating signal based on VCD(Value Change Dump) format data.
« Last Edit: Jun 22nd, 2009, 5:09am by pancho_hideboo »
