Jul 17th, 2024, 7:27pm
Monte Carlo simulation issues (Read 2704 times)
trashbox
Jun 26th, 2009, 5:24am
I'm using hspice to run Monte Carlo simulation and puzzled about the following questions:
#1. How many iterations is ok for MC simulation? If I set iteration very large, it'll spend too much simulation time.
#2. The foundry documentation shows I should set PROCESS Variability and MISMATCH respectively. So what's the difference between PROCESS Variability and MISMATCH? I ever think mismatch is the result of process variability.
#3. If I run MC simulation, should I also set corner? What's the difference between corner (fast/slow/typical) and Monte Carlo?
Thanks in advance!
boe
Re: Monte Carlo simulation issues
Reply #1 - Jun 26th, 2009, 5:54am
Hi trashbox,
#1: 100 runs is usually a good choice.
#2: Mismatch is local variation (different for different instances), Process variation is global variation (all devices see same variation - as in corner analysis)
#3: corner changes process parameters for all devices to worst-case values; MC process variation varies global process parameters statistically.
BOE
raja.cedt
Reply #2 - Jun 26th, 2009, 11:27pm
hi,
  the main difference between monte and corner simulation is in corner all devices has same characteristics(means ss corner every device is slow) but in monte you may have different lets say for a differential amplifier in corner simulation at least you wont see large offset voltage but in monte you may have one of the differential pair is slow another is fast so you will get worst offset voltage.
Rajasekhar.
trashbox
Reply #3 - Jun 28th, 2009, 6:48pm
Hi boe and raja.cedt!
Thanks very much. I got it. Smiley
