Jul 17th, 2024, 6:35am
What is the strict definition of a "compact model" ? (Read 2466 times)
engelbrl
Oregon State University
Jun 30th, 2009, 5:26pm
I need a true definition for a compact model.  I have read a couple of papers by Geoffrey Coram, and it looks like a compact model must:
1) have electrical inputs and outputs,
2) use equations written to ensure only real, physical behavior (i.e. continuous  derivitives), and
3) be relatively computationally efficient  (compared to what..?)
So the above could probably describe "other" sorts of models - what transforms a Verilog-A/MS model into a "compact model" ??
This definition is needed for my Thesis presentation and I know I will be asked for a clear, defining difference between this term "compact model" and "other" behavioral models....  please help!
Thank you,
linda
linda
Re: What is the strict definition of a "compact model" ?
Reply #1 - Jul 1st, 2009, 11:32am
3) ... compared to TCAD simulation.
2) is, alas, only true for *good* compact models Smiley
I would say a compact model is a behavioral model intended as a lumped-element replacement for a single device in circuit simulation.
engelbrl
Reply #2 - Jul 1st, 2009, 2:44pm
Thanks Mr. Coram - I appreciate response AND the fast reply!
Linda
linda
