Jul 21st, 2024, 2:13pm
Weird stability analysis results in a bandgap circuit (Read 9850 times)
HdrChopper
Jul 14th, 2009, 6:00am
All,
I'm analyzing the stability of a band-gap reference circuit in a BICMOS process. The gain of loop circuit is well known and
equal to the product of [GM(Q0)/gm(M0)] and [gm(M1)/gm(Q1)]; where GM(Q0) is the composite transconductance of Q0 and the 2K resistor.
When running the stability analysis with a probe located in A I get the expected low freq gain of ~ -8.2dB, as shown in the figure.
However when I move the probe to B the DC gain and the high frequency response both change drastically.
As far as I know the location of the probe for running stability analysis is not important as long as I place it in a single loop that
at least can include local feedback loops, like this is the case (beta helper of Q1 is another feedback loop).
Any hints or clues about what is going on? Anything I might be missing?
Your comments are more than welcome.
Tosei
Keep it simple
HdrChopper
Re: Weird stability analysis results in a bandgap circuit
Reply #1 - Aug 2nd, 2009, 11:11am
Nobody can help on this one?
Keep it simple
wave
Reply #2 - Aug 3rd, 2009, 4:21pm
HdrChopper wrote on Aug 2nd, 2009, 11:11am:
I have a hard time believing they are the *same* loop.
However, I can't quite convince myself why.
None the less, if the simulator indicates they are different, that is very likely the reason.
Wave
HdrChopper
Reply #3 - Aug 4th, 2009, 5:49pm
wave wrote on Aug 3rd, 2009, 4:21pm:
Hi Wave,
Thanks for your reply. Why arenīt you convinced the loop is not the same?
Both source A and B are in "series" with the signal.
In any case if you believe they are not the same, which one would you choose for analyzing stability for the band-gap? and why?  (you already know which one is correct. What I cannot get is why the other one is not.)
Tosei
Keep it simple
Reply #4 - Aug 5th, 2009, 9:24pm
Hi Tosei,
My simulation result is different from yours. Both A and B proves the same loop gain magnitude and phase response. The low-frequency loop gain is -8.37dB.
By the way, it seems that the 100 kOhm resistor can be removed. That has nothing effect on the function.
Yawei
raja.cedt
Reply #5 - Aug 6th, 2009, 7:44am
hi,
@Hi Tosei,
              i simulated the ckt what you have given in hspice ...it is giving more or less same results in both cases
@Yawei,
            how come you got same without 100k, i feel because of this resistor npn transistors are getting biased, correct me if am wrong
Rajasekhar.
HdrChopper
Reply #6 - Aug 6th, 2009, 7:12pm
Hi Yawei / Rajasekhar,
Thanks both for your inputs. Based on what you got I should assume there must be something wrong with my simulation set up, I guess?
Rajasekhar, I understand both cases should give exactly the same result, which is what Yawei got and I was expecting. However you said "more or less" the same result. What is the difference you observed?
Thanks and Regards
Tosei
Keep it simple
raja.cedt
Reply #7 - Aug 6th, 2009, 9:17pm
hi tosei,
          i did this simulation in hspise...so i used to put LC filter at the point where i want break...so what i feel is while doing this  some loading we have to take care  (generally i keep total ckt wherever i want to adjust loading )..but this will not give much difference  for this ckt....i got minute difference in the magnitude and no difference in the phase plot. In fact this expected because at A both sides are high impedance nodes..but at B one side is low impedance ........Let me know if any issue and thanks a lot because i learned a lot through this discussion
thanks,
Rajasekhar.
Reply #8 - Aug 9th, 2009, 1:58am
raja.cedt wrote on Aug 6th, 2009, 9:17pm:
hi tosei,
thanks,
Rajasekhar.
Hi Rajasekhar, you are right. So spectre has a convenient way, stb analysis, to check the loop gain/phase response without breaking the loop. It adopts the method named return ratio in fact. Please search IEEE or Paul Gray's textbook for return ratio.
Best regards,
Yawei
HdrChopper
Reply #9 - Aug 9th, 2009, 3:50pm
Hi Rajasekhar,
Actually the metod Yawei pointed out is the one I used for analyzing the stability of this circuit. My point is that according to this methodology theory the port which is used for computing the return ratio could be placed at any point in the loop. No loading effects has to be considered since the loop is not broken (therefore the loading conditions are intact).
However I got different results when placed at A or B.
Tosei
Keep it simple
Frank Wiedmann
Munich, Germany
Reply #10 - Aug 10th, 2009, 12:52am
ywguo wrote on Aug 9th, 2009, 1:58am:
Best regards,
Yawei
You can find the simulation method used by the stb analysis in http://www.kenkundert.com/docs/cd2001-01.pdf. Some more information about loop gain simulation is available on my webpage http://sites.google.com/site/frankwiedmann/loopgain.
Regarding the differences between Tosei's and Yawei's results: It might be helpful if you would post your netlists so that you can see if there are any differences between your simulation setups.
nobody
Reply #11 - Aug 10th, 2009, 3:55am
Frank proposes a good way to solve this problem.
I believe Yawei simulated that ckt using Spectre and it is
complicated to do loop gain simulation by using Hspice.
raja.cedt
Reply #12 - Aug 10th, 2009, 6:56am
hi,
  i am using hspice in office and may be i can use middle broke method in LT spice...if any body using hspice can you explain how you to do stability analysis in h spice......for my office work also i am using like LC method only
Rajasekhar.
