Andrew Beckett wrote on Jul 20th, 2009, 2:31pm:Actually it will only stop if they fail on the nominal run. Also, if the expressions are waveforms, you won't get histograms.
And what I said about doing Results->Evaluate Expressions still applies if you modify the expressions or add new ones.
Take a look in the mcparams and mcdata files in the monte dir alongside the netlist and psf dir, and see whether the parameter names have ended up in the scalar data file that is produced.
hi, i dont have waveform expressions, all of them are scalar.
what i did was exactly what you said, but the "adding expression" and "Results->Evaluate Expressions" thing still doesn't work. the new expression shows up in the mcparam file, but its results are not in mcdata file, and cannot be found by "Results->Plot->histogram". if i reload the results by "Results->select...", then the new expression can be found by "Results->Plot->histogram", but still not in the mcdata file, so it still can not be ploted. if i do "Results->Evaluate Expressions" after the reload, i get the following error:
*Error* _gets: argument #1 should be an I/O port (type template = "p") - nil
but thanks anyway for your patience.
