Aug 16th, 2024, 12:22pm
Hspice **warning** parameter em < 5.0e5 invalid (Read 2150 times)
qiushidaren
I am a lovely
MOSFET!
Chengdu
Jul 27th, 2009, 7:12pm
Dear all,
When I was doing post sim by using Hspice, here is a warning as follow, do you know how to fix it, thank you in advance!
set defaults em = 4.1e7 to run
-Terry
Re: Hspice **warning** parameter em < 5.0e5 invalid
Reply #1 - Jul 28th, 2009, 10:24am
EM is a BSIM3/BSIM4 parameter, and its default is 4.1e7, but the Berkeley code doesn't have any restrictions on its value -- if it's negative, the code skips a block in the 1/f noise evaluation.
If you're not doing noise analysis, I'd ignore it.  If you are, I'd contact the vendor and ask why you're getting that message.
qiushidaren
I am a lovely
MOSFET!
Chengdu
Reply #2 - Jul 28th, 2009, 10:57pm
Thank you Geoffrey_Coram, it really helps me a lot!
