Jul 17th, 2024, 4:20am
segmentation fault when I simulate a verlioga opamp model (Read 3628 times)
hhd1983
Jul 28th, 2009, 8:50pm
Hi, I wrote a simple opamp model with veriloga,
module test(in, ip,out);
input in,ip;
output out;
electrical in, ip, out;
parameter gain = 10000;
parameter bw = 100;
analog begin
  V(out) <+ laplace_nd(V(ip,in),{1},{1,1/(2*3.14*bw)});
But the simulator tell me a segmentation fault when I simulated it with spectre.
Can somebody help me? thanks.
Re: segmentation fault when I simulate a verlioga opamp model
Reply #1 - Jul 30th, 2009, 5:25am
You'll need to give more than that. I just threw together a simple testbench, and it simulated OK in MMSIM71.
So, you'll need to give the spectre netlist you're using, and ideally the subversion of spectre you're using (type "spectre -W").
andrew.
hhd1983
Reply #2 - Jul 30th, 2009, 7:21pm
Thanks for the reply.
The subversion of spectre is 5.10.41_USR3.102405, and the netlist is:
Quote:
I7(in ip net15) test gain=10000 bandwith=5M
C0(net15 0) capacitor c=1p
E1(ip 0 net3 0) vcvs gain=0.5
E0(in 0 net3 0) vcvs gain=-0.5
V0(net3 0) vsource mag=1 type=sine ampl=10m freq=5M
ahdl_include "/home/xxx/xxx/test/veriloga/veriloga.va"
analysis type "tran" "dc" "ac"
The file veriloga.va is:
input in,ip;
output out;
parameter bw = 100;
analog begin
That's all.
Regards.
hhd1983
Reply #3 - Jul 30th, 2009, 7:25pm
I find that it's no fault when I simulate it in Cadence 5.0.33. Is it a tool version problem?
Reply #4 - Aug 12th, 2009, 2:25pm
Both the IC5141 version and 5.0.33 are old (really unsupported) versions of spectre.
That said, I don't see the problem in the latest IC5141 version of spectre, nor with a more recent version (e.g. MMSIM71).
That said, you didn't include the complete netlist including analysis statements, so it's hard to be sure. I just used a somewhat arbitrary transient analysis, but I don't know what you were doing.
Also, your instance line for I7 uses a parameter "bandwith" (spelt wrong), whereas the veriloga has "bw". Not sure if that's relevant...
I tried it both as "bandwith" and "bw" and it worked in both cases for me.
So probably best just to try a more recent spectre version.
