Riad KACED
Swindon, UK
Hi there,
there are few steps that you need to follow to create a customized connect module for AMS in ADE:
1. Create the verilogAMS files for your connect Modules. Say I want to create a 1V connect module with following spec: Vsup=1.0, Vthi=0.666, Vtlo=0.333, Vlow=0 I copy the 1.8V connect module from my IUS stream , i.e $IUSHOME/tools/affirma_ams/etc/connect_lib/connectLib/ConnRules_18V_full_fast/co nnect/verilog.vams
The ConnRules_1V0_full_fast I'm about to create needs the following files :
Bidir_2.vams ConnRules_1V0_full_fast.vams E2L_2.vams E2R.vams ER_bidir.vams L2E_2.vams L2E_2_CPF.vams R2E_2.vams
All these files have been copied form : $IUSHOME/tools.lnx86/affirma_ams/etc/connect_lib
2. Prepare the environment: You need to have a correct hdl.var and cds.lib to compile the libraries. - An example of hdl.var is:
########## softinclude $AMSHOME/inca/files/hdl.var define ncuse5x define cdslib ./cds.lib Define WORK rkLib ##########
- An example of cds.lib is
------ softinclude $AMSHOME/tools/inca/files/cds.lib DEFINE analogLib $CDSHOME/tools/dfII/etc/cdslib/artist/analogLib DEFINE basic $CDSHOME/tools/dfII/etc/cdslib/basic DEFINE sample $CDSHOME/tools/dfII/samples/cdslib/sample Define rkLib ./rkLib Define myconnectLib ./rk_connect_lib/rkConnectLib ------
3. Compile the above connect modules using the following commands:
ncvlog -ams -use5x -work myconnectLib ./rk_connect_lib/ ConnRules_1V0_full_fast.vams ncvlog -ams -use5x -work myconnectLib ./rk_connect_lib/L2E_2.vams ncvlog -ams -use5x -work myconnectLib ./rk_connect_lib/E2L_2.vams ncvlog -ams -use5x -work myconnectLib ./rk_connect_lib/Bidir_2.vams ncvlog -ams -use5x -work myconnectLib ./rk_connect_lib/E2R.vams ncvlog -ams -use5x -work myconnectLib ./rk_connect_lib/R2E_2.vams ncvlog -ams -use5x -work myconnectLib ./rk_connect_lib/ER_bidir.vams ncvlog -ams -use5x -work myconnectLib ./rk_connect_lib/L2E_2_CPF.vams
4. Create a connectRules.il file with the above connect modules using the following command: genConnRulesFile -destpath ./rk_connect_lib/rkConnectLib -lib rkConnectLib ./rk_connect_lib/*.vams
5. copy over rk_connect_lib into your cadence working dir and update your cds.lib by adding: DEFINE rkConnectLib ./rk_connect_lib/rkConnectLib
6. Fire up Cadence and the ADE and load the created connect module. they must come in the list of available connect modules.
I have assumed you have created the necessary UNIX directories and file to go through the flow. Also, make sure that you put the 'connectRules.il' file in the connectLib library.
There is a snapshot of the directory tree
. |-- cds.lib |-- compileConnect (sh script for step3) |-- createConnectRulesFile (sh script for step4) |-- hdl.var |-- rk_connect_lib | |-- Bidir_2.vams | |-- ConnRules_1V0_full_fast.vams | |-- E2L_2.vams | |-- E2R.vams | |-- ER_bidir.vams | |-- L2E_2.vams | |-- L2E_2_CPF.vams | |-- R2E_2.vams | `-- rkConnectLib | |-- Bidir_2 | |-- E2L_2 | |-- E2R | |-- ER_bidir | |-- RK_CONNRULES_10V_FULL_FAST | |-- L2E_2 | |-- L2E_2_CPF | |-- R2E_2 | |-- connectRules.il | `-- inca.lnx86.172.pak |-- ncvlog.log `-- tree
Cheers, Riad.
