Hi Debjit,
It heavily depends on the size and mostly on the environment in which your model is being used. A buck model that works in a particular environment might have convergence problem when you put it in an integrated circuit. For top level integrated circuit such as a PMU (?) it is better to have very simple models, as suggested already. You may require to have models of different complexity for different situations. For top level connectivity verification I think one should have very simple models. May be omit stuff like PFM. Just flag a message that the block enters PFM, thats it!!!
This can speed up the whole simulation vastly, and also will have less trouble for the simulators to converge!
Finally, the simulator is also responsible for causing these convergence issues. It may not be entirely that the models are wrong. But then one of the biggest challanges is to develop a model that works in the given simulator. I assume you are using spectreVerilog (not only spectre) for top level sims. spectreVerilog is even more notorious when it comes to convergence!
Having said all these, it is undoubtedly good to have Verilog-A models that models many behaviors and yet helps quick simulation at chip level!!! But then time flies...
hope that helps..
cheers!
Rajdeep
