The C Model Interface is not included in the documentation by default, and is normally available by special request from Cadence. I believe it has been included in the Europractice bundle in the past (we've certainly had a very small number of support questions from Europractice about CMI), so your best bet is to contact Europractice support about this (who can contact Cadence in turn if needed).
There are very few cases where you really need to use the C Model Interface, so I'd first be sure that you can't implement what you're trying to do another way (say with VerilogA).
