Jul 21st, 2024, 4:20am
Wired net name in post-layout netlist (Read 2545 times)
Aug 06th, 2009, 3:12am
Hi Guys,
The layout is extracted with Assura. Then I ran a post-layout simulation with a config view, in which the av_extracted view is instantiated instead of schematic vew. However, the net names in schematic has not one to one map in the av_extracted view because it is extracted with distributed RC mode. The net is cut into dozens of segments with wired net names. For example, the net name I111_n13 becomes a few nodes like _29:\I111_n13.
When I tried to plot/save the net voltage in ADE, it failed to find the net unfortunately.
Open ADE, choose outputs -> Output Setup, fill in Expression I5/_29:\I111_n13. It becomes (I5/_29 : \I113_n13) automatically.  >:(
I think there must be something wrong. Any comments are appreciated.
Yawei
Re: Wired net name in post-layout netlist
Reply #1 - Aug 15th, 2009, 1:15am
Try clicking on the node in the extracted view and seeing what it gives you? I suspect there needs to be a leading / at the very least...
Reply #2 - Aug 16th, 2009, 2:31am
More Detail...
For example, I just did this and got:
/I1/17:SIDDQb
The hierarchy delimiter will be "/", and there should be no backslash. You're probably looking at netlist names.
I did this by doing Outputs->To Be Saved (or Plotted).
If you do Outputs->Setup, you can't just type in a hierarchical name. It needs to be an expression, so would be something like:
v("/I1/17:SIDDQb" ?result 'tran)
or
VT("/I1/17:SIDDQb")
