Sep 16th, 2026, 10:51pm
Decimal to binary conversion (Read 1865 times)
nishant22
Aug 11th, 2009, 2:06am
hi,
I am writing a testbench, with  stimulus in VA in which I have few buses of width around 69 bits, so I want user to specify the decimal value and my resepective data paths get ON or off basically get 1 or 0. So I want to carry out Decimal to binary conversion in VA. So if u specify decimal value of 4 and my bus is 40 bits, i shud get 0...0100 . I want to write this model in pure verilog-A not ams for some restrictions. Can anyone please help or send me a code, its re\ally urgent.It would be really useful. I have seen many C/C++ codes, but VA restrictions don't allow me to use those functions.
Thanks ,
NIshant
nishant22
Re: Decimal to binary conversion
Reply #1 - Aug 14th, 2009, 1:27am
Hello All.
can anyone please help?
Sumit Adhikari
Reply #2 - Aug 14th, 2009, 5:03am
use it like following
integer val_int  ;
real     val_real ;
logic  [68:00]  your_bus ;
always @(val_int) your_bus = val_int ;
analog
begin//{
  val_int = val_real ;
end//}
boe
Reply #3 - Aug 14th, 2009, 6:20am
Please note that real does not have a resolution of 69 bits (Standard IEEE double precision real has a 52-bit mantissa).
BOE
Added: Verilog-A does not guarantee integers to be larger than 32 bit either.
PS: Is your signal constant?
« Last Edit: Aug 14th, 2009, 8:46am by boe »
