Jul 20th, 2024, 10:19pm
analog multiplexer for simulation (Read 832 times)
analogue_guy
Aug 18th, 2009, 12:39am
I am using specre and for a testbench I would need an analog multiplexer, what I can control via a variable setting or any similar handy way.
My goal is basically: I want to change the load of a circuitry in a simple way and I want to edit the testench once, after I just want to set a variable or somethig like that.
I hope you have some idea. Thanks ...
--AG
HdrChopper
Re: analog multiplexer for simulation
Reply #1 - Aug 18th, 2009, 6:23pm
You can easily build one with ideal switches, from the analoglib.
These can be controlled by means of a variable you can set....
The cell is simply called "switch".
Hope this helps
Tosei
Keep it simple
analogue_guy
Reply #2 - Aug 19th, 2009, 7:50am
HdrChopper wrote on Aug 18th, 2009, 6:23pm:
Hope this helps
Tosei
would be a possibility
Actually I target a Verilog-A solution, then I could simply define one variable and I could even sweep it in simulation.
Simply placing shorts or opens to branches...
But I end up with that in many problems in simulation (convergence ...)
HdrChopper
Reply #3 - Aug 19th, 2009, 3:58pm
Certainly a verilog-A solution is another option.
The convergence problems you are pointing out might be related to the very high impedance on the terminals of your verilogA block.
If you use switches as I suggested you can more easily avoid these problems.
Tosei
Keep it simple
