Jul 17th, 2024, 4:34am
case statement in verilog-A (Read 13469 times)
rajdeep
UK
Aug 21st, 2009, 3:52am
How will spectre simulate case statement in Verilog-A?
case(sum)
0: vnom = 1.2;
1: vnom = 2.3;
endcase
In the above example will the entire section be simulated at every time point or will it be intelligent enough to simulate the section only when there is a change in sum??
Im curious because what if I have the following statement in conjunction with the above statement..
V(vout,gnd) <+ transition(vnom,td,tr);
If spectre evaluates vnom at every timepoint then the argument of transition will be evaluated at every time point. Wont it slow down the sim unnecessarily?
I have tried to wrap up the case statement within a cross statement just to experiment and frankly speaking there was absolutely no difference!!! But that could be because of the simplicity of the testbench...any thoughts?
Thanks much!
Rajdeep
Re: case statement in verilog-A
Reply #1 - Aug 21st, 2009, 12:56pm
You might want to read through this thread:
http://www.designers-guide.org/Forum/YaBB.pl?num=1220537539/0#0
It looks like you picked a formulation that is similar to the faster of the two approaches mentioned.
Sumit Adhikari
Reply #2 - Aug 22nd, 2009, 8:24pm
It wont work. There is no tigger for the case statement.
Write is as follows :
always @(*)
case(sum)
 0: vnom = 1.2;
 1: vnom = 2.3;
endcase
Further it will give u an error as you are using vnom in analog block
and it is not initialize. Initialize it. Following could be a nice approach:
always @(*)
case(sum)
 0: vnom = 1.2;
 1: vnom = 2.3;
 default : vnom = (whatever_value_you_choose);
endcase
Sumit
Reply #3 - Aug 24th, 2009, 4:46am
Sumit -
I think rajdeep was intending for the case statement to be in the analog block also, along with the transition, in which case the trigger is not needed.
rajdeep
UK
Reply #4 - Aug 27th, 2009, 6:07am
Hi Geoffrey!
Thanks for the link! I remember to go thru that thread once before!! So, I guess the conclusion is to make vnom change only when sum changes i.e. wrap the case statement within a cross statement. This will make the transition filter work faster!
@Sumit: Im using Verilog-A, not Verilog-AMS. Sorry for the confusion!
Rajdeep
