It depends on whether you want the resulting netlist input.scs to contain the design variables and analysis statements. If at line 3 it won't contain the analysis statements or design variables; if at line 6 it will. However, since the run() statement is present, it will produce the input.scs with the analyses and design variables anyway.
So the createNetlist(?recreateAll t) is purely for the purpose of forcing a renetlisting, rather than rely on the incremental netlister. Therefore it shouldn't matter where you put it.
You can use this (in IC5141) by doing:
icfb -restore oceanScript.ocn
You cannot (as I said before) use the ocean executable in IC5141 because that doesn't have the ability to netlist (it does in IC613 though).
