vivkr
Hi Frank,
Thanks for the link. Actually, I already tried out all those methods. I had asked a similar question long ago and had tried using the solutions posted then, both the method using scasubckt, and the other one creating a spectre view, updating CDF etc.
It turns out that the problem requires another solution which is due to some mixing and hacking used by the vendor supplying my design kit. So I needed to use a custom script which is supplied for this task. However, your other solutions remain relevant in general.
Vivek
