Jul 21st, 2024, 12:20pm
is it possible to override a subcircuit in schematic with  a netlist? (Read 2439 times)
mydreamhouse
Sep 26th, 2009, 4:44am
i have a subcircuit in schematic  and a subcircuit netlist , can i override the schematic with netlist in ADE(cadence spectre)? ( they have the same ports)
View Profile mydreamhouse   IP Logged
Riad KACED
Swindon, UK
Re: is it possible to override a subcircuit in schematic with  a netlist?
Reply #1 - Sep 28th, 2009, 1:30pm
I think this is possible. One way of doing it is to generate a Spectre view for your subcircuit. Go the the lib manager and copy the symbol view to spectre view. You then need to use a configured schematic from the HED using a Spectre template. If you want to simulate the schematic, then make sure that you cell is bind to schematic view in the HED. Otherwise, to use the subckt, you need to change the binding to Spectre and include the subckt netlist into your model library.
This should do what you are asking for !
Cheers,
Riad.
Riad KACED
PDK, EDA Support Engineer.
Frank Wiedmann
Munich, Germany
Reply #2 - Sep 29th, 2009, 12:48am
