Jul 21st, 2024, 10:22pm
IC5141 Problem (Read 2003 times)
elvan
IC5141 Problem
Oct 05th, 2009, 7:27am
I can not load the simulation setup states which have been saved ,suchs as Analysis , Codition Setup ....
Coud anyone know the solution
Re: IC5141 Problem
Reply #1 - Oct 5th, 2009, 1:23pm
You haven't given us much to work with ... how are you trying to load them?  How were they saved?  What error message do you get?
Riad KACED
Swindon, UK
Re: IC5141 Problem
Reply #2 - Oct 5th, 2009, 2:43pm
Besides, It's good telling us which version of IC5141 you are using. I'm not suspecting any bug, just in case ...
You can get your versions by typing the following UNIX commands from a terminal where you have already acquired IC5141:
UNIX> icfb -V
UNIX> icfb -W
Cheers,
Riad.
Riad KACED
PDK, EDA Support Engineer.
