Jul 17th, 2024, 6:33am
Running code depending on clock and time. (Read 2117 times)
eddie
Oct 06th, 2009, 5:15am
Hello Everyone.
Just a quick query.
I have a block of code that needs to run on the leading edge of a clock (so I intend to look at the voltage, if v > a threshold, then run the code).
But I need the code to run for a time longer than the pulse with of the clock, lets say 3 clock cycles. If I use the conditional with a threshold it will see the leading edge but as soon as the simulator runs the block of code again when the clock is low the code I need running will stop, as naturally v is less than the threshold.
Any way I can detect the rising edge and set the code going until a time or event later.
Btw, the code implements a RC time constant discharge. The problem I have at the moment is that as soon as the pulse goes low the discharge stops prematurely.
Thanks.
Ed
Re: Running code depending on clock and time.
Reply #1 - Oct 8th, 2009, 6:13am
Is this Verilog-A?  What sort of a net is your voltage?
@(initial_step) active = 0;
@(cross(V(in) > vth)) active = 1;
if (active) begin
// do your code
rajdeep
UK
Reply #2 - Oct 9th, 2009, 4:02am
You can schedule events in Verilog-A. But Im not sure whether your code is in  Verilog-A or Verilog-AMS. I guess in Verilog-AMS things could be easier for you.
Anyway not sure abt the question!! :-p
Rajdeep
