eddie
Hello Everyone. Just a quick query. I have a block of code that needs to run on the leading edge of a clock (so I intend to look at the voltage, if v > a threshold, then run the code). But I need the code to run for a time longer than the pulse with of the clock, lets say 3 clock cycles. If I use the conditional with a threshold it will see the leading edge but as soon as the simulator runs the block of code again when the clock is low the code I need running will stop, as naturally v is less than the threshold. Any way I can detect the rising edge and set the code going until a time or event later. Btw, the code implements a RC time constant discharge. The problem I have at the moment is that as soon as the pulse goes low the discharge stops prematurely. Thanks. Ed
