Jul 17th, 2024, 6:41am
Implementation of Verilog-AMS in AMS Simulator (Read 2795 times)
Emmanuele
Geneva, Switzerland
Oct 15th, 2009, 1:58am
Hi to everybody!
I've just begun learning Verilog-AMS language, and my first concern is the possibility to use the created file in AMS Simulator (in Cadence SPB 16.01).
It's not very clear to me how I can implement a verilogams file in a model; normally I use Design Entry HDL, which theoretically gives the possibility to add parts modeled with Verilog or VHDL.
Nevertheless, I tried to import simple programs (written in a notepad file) using Part Developer, and it gave me plenty of errors.
For example, I tried the first one proposed in the manual:
module shiftPlus5(in, out);
input in;
output out;
voltage in, out; //voltage is a signal flow
//discipline compatible with
//electrical, but having a
//potential nature only
analog begin
V(out) <+ 5.0 + V(in);
but I got errors like "Import failed because of an error on line XXX and token 'YYY' in file ZZZ. Correct the input file and reimport."
Any suggestions?
Thank you for the help you'll give me.
Cheers,
Emmanuele
Frank Wiedmann
Munich, Germany
Re: Implementation of Verilog-AMS in AMS Simulator
Reply #1 - Oct 15th, 2009, 2:49am
Most people in this forum, including myself, are using the Virtuoso IC design software from Cadence and do not have any experience with Cadence SPB.
Riad KACED
Swindon, UK
Reply #2 - Oct 15th, 2009, 2:50pm
Hi Emmanuele,
I use the AMS Designer in Virtuoso too.
If you are writing verilog-A (the above code I meant) instead of verilog-AMS, then stick at the Spectre simulator as Spectre compiles verilog-A, not verilog-AMS. This would save your licenses.
Cheers,
Riad.
Riad KACED
PDK, EDA Support Engineer.
Reply #3 - Oct 20th, 2009, 5:22am
This looks like the same issue as in this thread:
http://www.designers-guide.org/Forum/YaBB.pl?num=1255439237/9#9
Please read the responses there.
