Riad KACED
Swindon, UK
Hi Rajesh,
Most of the analog books are helpful to get you sorted out. You must consider the allowed current consumtion for your amplifier and most importantly get it stable. Higher static gains are very likely to put you into oscillation !
BTW, I don't think this is the right forum to ask, you better go into the analog design. Once you have thought of the architecture then simulation wise is something we can handle in here.
Cheers, Riad.
