Aug 16th, 2024, 8:28pm
AMS Simulations Running Slow (Read 5137 times)
QuantumSimulator
Oct 22nd, 2009, 9:57am
Hello All. I am running topLevel AMS simulations and  the simulator is running extremely slow. Basically, simulations that took 11 hrs now take 130 hrs!. Sim steps get smaller and smaller or they remain the same 20.11ps, 20.11ps .............20.11ps. I tried to find anything oscillating and I could find none. I relaxed torelerances and this helped one sim but not the second sim. Any ideas I can try.....?
Thanks in advance
QuantumSimulator
Riad KACED
Swindon, UK
Re: AMS Simulations Running Slow
Reply #1 - Oct 22nd, 2009, 11:36am
Hi there,
What I tend to suspect in this kind of cases is a verilog-AMS block with an always statement without any sensitivity list. something like
  always
  begin
    out=1.0-in;
Now if I add 'in' in the senstivity list, then the code gets aveluated only when 'in' changes.
 always @(in)
  begin
    out=1.0-in;
This was just a guess.
AMS Designer comes with utility called 'NC Profiler'. You can invoke this tool by adding the -profile option to the ncsim command line. If you are using AMS from ADE, then you would be able to setup the profile from ADE -> Simulation -> Options -> AMS Simulator and then turn on the 'Generate runtime profile' switch. You then need to re-run and exit the simulator to get the profiler resulted dumped into the ncprof.out file.
Hope this helps !
Cheers,
Riad.
Riad KACED
PDK, EDA Support Engineer.
QuantumSimulator
Reply #2 - Oct 24th, 2009, 7:39pm
Thanks Raid for the suggestion. I could not find "always" statement without @.
Riad KACED
Swindon, UK
Reply #3 - Oct 25th, 2009, 4:18am
Did you look at the profiler ?
Does your simulation spend time in the digital or Analog solver ?
When I get slow simulation, I usually look at the inserted connect modules as well. Using either the ncelab -iereport option (available from ADE as a switch) or using the TCL debug from ncsim:
> scope -aicm -rec -hier.
The ierport gives a good summary at the end.
You case is a bit odd though because your AMS simulation is even slower than your Spice level simulation, isn't it ?
This may be wither:
1. A digital statement hanging around
2. A convergence issue with Verilog-A blocs.
3. A bug somewhere.
What I usually do to narrow down this kind of issues is:
1. I run AMS Designer in Spectre direct like way. In other words, I set up the config so to reproduce the Direct Spectre simulation from within the AMS Designer. I don't use any digital, RTL ... etc. Just transistor level + Verilog-A just as run by spectre outside AMS. Ideally, you simulation would run just as fine as Spectre. If not, it means that the Spectre version used by AMS has got some issues and you need to report this to Cadence Customer Support. Otherwise, if all works fine, then you need to look at the profiler to see where the simulation spends most of the time. You may also need to report you issue to cadence Customer Support.
Cheers,
Riad.
Riad KACED
