Aug 16th, 2024, 10:19pm
can i do nyquist criterion in cadence (Read 1123 times)
cczhang
Oct 23rd, 2009, 1:07am
hi  i want to know can i do nyquist criterion in cadence. the version of cadence is ic5141. if it can be done, ple tell me how to do it. thanks very much
and also i want to know how to start stb simulation in cadence. thanks
zcc
buddypoor
Bremen, Germany
Re: can i do nyquist criterion in cadence
Reply #1 - Oct 23rd, 2009, 1:16am
cczhang wrote on Oct 23rd, 2009, 1:07am:
zcc
Of course, you can. All you need is an ac analysis and the capability to draw the imaginary part of the loop gain vs. the real part.
cczhang
Reply #2 - Oct 23rd, 2009, 1:39am
Of course, you can. All you need is an ac analysis and the capability to draw the imaginary part of the loop gain vs. the real part. [/quote]
hi ,could you explain more details how to use? thanks
for example how can i get the trans function of loop gain and how can i draw the imaginary part of the loop gain vs. the real part?
buddypoor
Bremen, Germany
Reply #3 - Oct 23rd, 2009, 2:59am
cczhang wrote on Oct 23rd, 2009, 1:39am:
I am afraid you are not very familiar with the subject - and therefore, itīs not easy to explain in detail the meaning resp. simulation alternatives for loop gain. I am not working with Cadence, but with a lot of other simulation programs - nevertheless I am sure that you can ask cadence to plot IM(L(s)) if L(s) is the loop gain.  And than you can change the x-axis to show R(L(s)). And this gives you the NYQUIST plot.
I repeat: At first you have to become familiar with the term loop gain - and how to simulate it. This item has been discussed very often in this forum.
Regards + good luck.
cczhang
Reply #4 - Oct 25th, 2009, 5:54pm
thanks very much.
larry flowers
toronto
Reply #5 - Oct 5th, 2012, 7:04am
Hi
If you just want results for some application purpose and this simulation is not specific to just cadence ;  then i think you can do this better at MAT-LAB simmulink. Mat lab has built in function for Feedback loop gain.
For 'gain' : It is the measure of ability of a system to increase its output (Power , Amplitude) with respect to Input.
For 'Loop gain' :  If this gain is controlled by some feed back then it is called loop gain.
Remember adding Loop to some system decreases its overall gain.
Nyquist Criterion :  It tells whether the system under consideration is stable or not and if not stable what changes can be done to make it stable !
This is actually dealing with complex variables in terms of systems  ;)
and Plotting results.
thanks
boe
Reply #6 - Oct 5th, 2012, 9:32am
larry flowers wrote on Oct 5th, 2012, 7:04am:
... Mat lab has built in function for Feedback loop gain.
So does Cadence.
- B O E
