Aug 15th, 2024, 11:35pm
Pull-up circuit in USB IO transceiver... (Read 3608 times)
somisetty
Nov 09th, 2009, 8:41pm
Hi All,
Is there any particular reason why most of the USB IO Transceivers,prefer Pull-up circuit at the output?
raja.cedt
Re: Pull-up circuit in USB IO transceiver...
Reply #1 - Nov 9th, 2009, 9:26pm
hi,
   i guess it's 50 ohms termination...
rajasekhar.
casual
Ex Member
Reply #2 - Dec 15th, 2009, 6:11pm
Most of the time, USB will be in idle mode, then the driver can be in tristate mode (not consuming power) and let the weak pull up resistor pull the signal to a known voltage instead of tristate/floating. Beside this, receiver also need to sense the speed mode based on the pull-up resistor setting.
  IP Logged
