jdac_18
I would like to simulate the effects of jitter, but instead of using the standard jitter model, I would like to just randomly delay (positive and negative time) the clock signal. I input the clock signal and then use the latest crossing function and timer to generate a signal. The following is the code I have written:
module timer_test(input_clk, output_clk,rand_tp); input input_clk; electrical input_clk; output output_clk; electrical output_clk; output rand_tp; electrical rand_tp;
parameter integer start_range=-100; parameter real fs=1/1n, vth=0.5; integer seed, end_range; real ran_num,period,d,rand_t,previous,latest; analog begin @(initial_step) begin seed = 50; end_range=100; previous=0; end ran_num = $rdist_uniform(seed, start_range, end_range); rand_t=ran_num*1p; period=1/fs/2; @(cross(V(input_clk)-vth,+1))begin previous=latest; end @(timer(latest+100p))begin d=1; end @(timer(latest+period+100p))begin d=0;
end latest=last_crossing(V(input_clk)-vth, +1); V(output_clk)<+transition(d, 0, 30p, 30p); V(rand_tp)<+transition(rand_t,0,0,0); end endmodule
The problem is that the random number generated doesn't delay the signal created by the timer function. Is there a way to generate random delay?
Thank you
