Aug 16th, 2024, 10:03am
error while simulating using AMS in cadence (Read 2558 times)
bharath
Dec 14th, 2009, 12:15pm
I have a verilog-ams block of low pass fitler...
analog
     begin
           V(filt_out) <+ laplace_nd(I(filt_in), {1,r1*c1}, {0, c12 , r1*c1*c2+ r2*c3*c12, r1*r2*c1*c2*c3}) ;
i have initialised r1,r2,c1,c2,c12,c3 as real and proper values
when i simulate i get the following error
       coefficient of the highest power of `s' filterdenominator is zero.This
       error commonly arises if the coefficients are initialized inside an
       @initial_step statement that does not account for the analysis during
       which this error was reported.
I am new to Verilog-AMS so dont know where i am going qrong ..
Re: error while simulating using AMS in cadence
Reply #1 - Dec 14th, 2009, 12:55pm
Try replacing the variables with numbers just to see if the variables aren't being set properly.
I forget: is the first coeff in the denominator the highest power of s or the lowest?
bharath
Reply #2 - Dec 14th, 2009, 1:18pm
I will try setting the values instead of variables
the first co-efficient is the lowest power of s -- atleast according to Verilog LRM manual.
Peruzzi
Reply #3 - Jan 2nd, 2010, 5:55pm
Bharath,
You can only use constants or parameters as laplace_nd coefficients, not variables.  If you must use variables, convert your H(s) into a set of differential or integral equations.
Cheers,
Bob P.
www.RPeruzzi.com
