Sep 20th, 2026, 5:09pm
Passing model file as a string parameter in cadence ocean script (Read 3810 times)
pkd
India
Dec 22nd, 2009, 4:53am
I want to do a corner analysis along with several other variable
parameters for my design.
At present the line specifying the model file looks like this...
modelFile(
  '("/home/pratap/cadence/foundry_data/umc13mmrf/../Models/Spectre/
L130E_HS12_V241.lib.scs" "ss")
All I need to change is the last argument as "ff" or "tt". So I want
to give these strings as parameters from an array and run the
simulation.
Does anybody have an idea how can I do so?
Waiting for some solution,
-pkd
Re: Passing model file as a string parameter in cadence ocean script
Reply #1 - Dec 22nd, 2009, 5:04am
pkd
India
Reply #2 - Dec 22nd, 2009, 3:50pm
Thanks!
The link helped me get the vital clue.
This is how my final code looks like...
corners='( "ss" "tt" "ff" "snfp" "fnsp" )
foreach(corner corners
  modelFile(
   list( "/home/pratap/cadence/foundry_data/umc13mmrf/../Models/Spectre/L130E_HS12_V241.lib.scs" sprintf( nil "%s" corner))
Reply #3 - Dec 23rd, 2009, 12:57am
"sprintf()" is not required at all for your case.
The following works for your purpose.
  modelFile(
   list( "/home/pratap/cadence/foundry_data/umc13mmrf/../Models/Spectre/L130E_HS12_V241.lib.scs" corner )
