Vinay,
Have you tried to simulate? Do you have a problem when you simulate? Basically, if you should be able to run ADE from Composer in this case. The only complication will come if you have a schematic view and an verilog-a view for the DAC. In that case you can control the order for netlisting using the view order list, Setup --> Environment --> Switch view list.
