Jul 16th, 2024, 1:45pm
vbox and Vgb (Read 1434 times)
vbox and Vgb
Jan 13th, 2010, 12:43pm
Does anyone know, in Spectre, whether Vgb is checked against vbox?
Or are only Vgs and Vgd checked against vbox?
Should Vgb be checked against vbox, or is some of the gate to body potential dropped across the silicon between the body contact and the point right under the gate?
Generally, the source and drain diffusions are close to, and even underlapping, the gate, so Vgs and Vgd are likely to be the voltage the oxide actually experiences.
