Jul 2nd, 2025, 1:02pm
Does tnom in netlist options override tnom setting in models files? (Read 5622 times)
CircuitNerd
Jan 21st, 2010, 3:00pm
Which tnom setting takes precedence in the Spectre simulator - the one you set in the .options statement (top level netlist), or the value set inside the models files (called by .include statements in the top level netlist)?
Re: Does tnom in netlist options override tnom setting in models files?
Reply #1 - Jan 22nd, 2010, 8:01am
The tnom on the model has higher precedence (for that model).
If you look at spectre -h bsim4 (say), you'll see:
326     tnom (C)          Parameters measurement temperature. Default set by
                          options.
and spectre -h options:
6       tnom=27 C         Default component parameter measurement temperature.
So put another way, the temperature at which the model was characterized is specified by tnom in the model, and if that's not set, by tnom in the simulator options, and if that's not set, it will be 27.
CircuitNerd
Reply #2 - Jan 22nd, 2010, 12:36pm
Thanks for your reply. Interestingly, it is EXACTLY THE OPPOSITE of the answer from my CAD group.
So, can you prove the validity of your assertion by citing any Cadence documentation (e.g. Spectre Reference Manual, pg. 72) or something similar? I personally believe you are correct, but if I can cite vendor docs to prove it, convincing the CAD armada will certainly be much easier...
Thanks!
Reply #3 - Jan 22nd, 2010, 3:08pm
Given that parts of the documentation are built from the "spectre -h" text, you should find exactly the same definitions in the spectre manuals. I'm at home right now, so can't easily look it up, but I'm sure you can...
If you think about it, having the opposite behaviour would be rather strange - it would mean that your carefully characterized models, each characterized at a defined nominal temperature, would then get messed up by somebody overriding it globally.
It would be rather strange to have a global overrules local approach. Not unheard of though, I guess. HSPICE has (or least had, I'm not sure what the default is these days) a rather counterintuitive global wins over local parameter approach. I remember arguing this with Meta-Software nearly 20 years ago, and they then added the PARHIER parameter to change the parameter inheritance to be the more conventional  local wins over global.
Andrew
Reply #4 - Jan 23rd, 2010, 8:51pm
Here's the proof (better than just referencing the manual, I got the simulator to tell me). If you use this netlist:
model withTnom bsim4 type=n tnom=50
model withoutTnom bsim4 type=n
MwithTnom (d g s 0) withTnom w=1u l=0.5u
MwithoutTnom (d g s 0) withoutTnom w=1u l=0.5u
opts options tnom=34
models info what=models where=screen
This (as you can see) has two models defined, one which explicitly sets tnom to 50, and one which doesn't have it set. Additionally I have the global tnom set in the options statement. Finally I'm using an info analysis to output all the model parameters.
Here's what it produces (irrelevant parameters chopped out for the sake of brevity) using the latest MMSIM71 ISR (what I had handy):
Model parameter values `models':
Model: withoutTnom
Primitive: bsim4
       type = n
      level = 14
       fcsw = 500e-03
       tnom = 34 C
      trise = 0 C
        ute = -1.5
Model: withTnom
Primitive: bsim4
       type = n
      level = 14
       fcsw = 500e-03
       tnom = 50 C
      trise = 0 C
        ute = -1.5
So that proves what I was saying - the global option only affects models which don't have tnom explicitly set themselves. Hope this helps to convince your CAD group!
CircuitNerd
Reply #5 - Jan 26th, 2010, 8:15am
Well, that looks pretty conclusive! Thanks for your efforts.
CircuitNerd
