Jul 18th, 2024, 2:21pm
spectreVerilog crashing! (Read 6647 times)
rajdeep
UK
Jan 26th, 2010, 6:34am
I am running a chip level sim with spectreVerilog. I am also trying to read VCD file. For some strange reason the sim is crashing once the VCD file starts sending its data with an error message stating: internal assertion failed in devices.c at line no 4056. Please run `getSpectreFiles' or send the netlist, the spectre log file, the behavioral model files, and any other information that can help identify the problem to support@cadence.com.
I am sorry I am not able to give the exact error message as I have started another sim at the same place after changing from 32 bit to 64 bit option hoping it would help!!
But in general, can anyone share some experience abt this kind of error message?
Thanks!
Rajdeep
rajdeep
UK
Re: spectreVerilog crashing!
Reply #1 - Jan 26th, 2010, 7:28am
Hi there!
This is the error message:
Internal error found in spectre at time = 6.99849 ms during transient analysis `tran'.  Please run `getSpectreFiles' or send the netlist, the spectre log file, the behavioral model files, and any other information that can help identify the problem to support@cadence.com.
   FATAL (CMI-2010): Assertion failed in file `devices.c' at line 5872.
   FATAL (SPECTRE-21): Assertion failed.
Can anyone help me to avoid this problem? Like if there are any gen methods to handle such problems??
Thanks!
Rajdeep
Reply #2 - Feb 1st, 2010, 10:26am
AFAIK, the "general method" to handle this is to send the test case to Cadence.  It's not like the source code (devices.c) is available to you.
At best, you might be able to guess what device is causing the problem (CMI-2010 may indicate it's a device loaded via CMI rather than built-in), but I don't know what you'd do with that info.
Reply #3 - Feb 2nd, 2010, 11:21am
The CMI-2010 error code unfortunately is not that specific. It's a bit of a catch-all... The line in the code might help us (Cadence debug it), but at the very least we'd need to know what subversion of spectre you're using.
The best thing would be to contact Cadence customer support as the message actually suggests you to do, as Geoffrey pointed out.
