Aug 15th, 2024, 10:22pm
Ideal transmission line in Cadence (Read 14132 times)
gocoba
Arizona
Jan 26th, 2010, 6:57pm
Hi there,
I have a question,  is there an ideal transmission line model in Cadence like TLine in ADS? ADS has ideal Tline models and I use them to get the electrical length values I need. Then I use some EM software like Sonnet, etc to model my lines to get as close a match as possible to the ideal line electrical length and characteristic impedance values.
So, just wanted to know if there is ideal one in Cadence.
Thanks!!
Albert
Re: Ideal transmission line in Cadence
Reply #1 - Jan 26th, 2010, 7:20pm
gocoba
Arizona
Reply #2 - Jan 27th, 2010, 5:13pm
Hey thanks!!
But I have a question of setting up these parameters in Tline.
Suppose I have a line with 30 degree at 60GHz, suppose there is no delay time (ideal line only), what should I set for physical length?
30/360 * lamda = 1/12* 3e8/60e9 = 420um? I dont have to consider dielectric constant since this is a perfect line, is that correct? Also, what is the normalized length? the default is 0.25, does that mean it is set to be a quarter wave TL?
Thanks a lot in advance!
Reply #3 - Jan 28th, 2010, 3:25am
gocoba wrote on Jan 27th, 2010, 5:13pm:
What do you mean by no delay time (ideal line only) ?
Right.
beta=2*pi/lamda, theta_rad=30/180*pi,
Length=theta_rad/beta=30/180*pi*lamda/(2*pi)=30/360*lamda
is that correct?
Correct.
However "dielectric constant" is considered as wavelength or wave velocity equivalently.
Yes.
Read message of "spectre -h tline" surely, before posting questions.
« Last Edit: Jan 28th, 2010, 8:37am by pancho_hideboo »
