Jul 16th, 2024, 1:32pm
Probe inside a verilog-A module (Read 4948 times)
Feb 04th, 2010, 8:46pm
Hi Guys,
How do I probe inside a verilog-A module? As well known, signals and variable can be defined in side a verilog-A module. I am simulating a behavioral model written in verilog-A. I want to probe inside the verilog-A module to debug.
The simulation tool is spectre. I use ADE as the GUI interface.
Yawei
Re: Probe inside a verilog-A module
Reply #1 - Feb 5th, 2010, 2:03am
Hi Yawei,
In the Outputs->Save All form, set the "saveahdlvars" setting to "all".
Then  you'll be able to see internal variables in the results browser.
Reply #2 - Feb 6th, 2010, 8:11pm
Thank you, Andrew.
