The followings are general notes.
Always describe vendor's name which you use as tool or simulator. - There are many simulators which have analyses called as PSS, PAC and Pnoise.
- Describe in detail with using correct terminologies.
- Warnigns are different from Errors.
- ADS is not name of simulator.
- There is no tool which name is Cadence.
- Don't use Direct Plot of Cadence ADE blindly without knowing definition.
- All gains in Direct Plot of Cadence ADE are "right", "true" and "practical" voltage gain.
- Don't mix up Simulation with Post Processing. They are completely different phase.
- MATLAB are different from Simulink.
- Learn measurements using actual instruments. Not "EDA Tool Play
ic_engr wrote on Feb 9th, 2010, 5:51am:I donot see this source is Cadence analogLib nor in ahdlLib.
This source is available in adsLib for Cadence DFII.
If you don't have Agilent RFDE, you have to create custom source by Verilog-A.
I can easily create custom source which realize same function as "VtRF_Pulse" in "adsLib" by Verilog-A.
Burst sinusoidal is no more than ASK or OOK signal.
So if you don't have skill to write custom source by Verilog-A, use combination of vsin, vpulse and multiplier.
