Jul 16th, 2024, 7:24pm
burst source (Read 8748 times)
ic_engr
burst source
Feb 08th, 2010, 11:52am
I need to use  a burst sine wave. Basically a sine signal with abitlity to repeat with  a burst frequency.
Any Ideas.
ic_engr
Re: burst source
Reply #1 - Feb 9th, 2010, 3:38am
Not sure I understand what you're asking. Perhaps a picture or reference might help?
What varies over time? A sine wave is normally repeating, so I'm not sure what the "burst frequency" is for - what does it actually change?
This might be a well known term, but it's not well known to me!
ic_engr
Re: burst source
Reply #2 - Feb 9th, 2010, 5:16am
What I need as a sourse is a periodic sine signal which turns on and off at a specific rate. For example, a 100Hz sine wave that starts at 1msec and then after few cycles of 100Hz turns-off and then repeats.
I may be able to do this using switches but was hoping to get something more generic from the sources available may be even in ahdl.
ic_engr
Re: burst source
Reply #3 - Feb 9th, 2010, 5:33am
ic_engr wrote on Feb 8th, 2010, 11:52am:
Use the following.
http://edocs.soco.agilent.com/display/ads2009/VtRF+Pulse+%28Voltage+Source%2C+RF...
ic_engr
Re: burst source
Reply #4 - Feb 9th, 2010, 5:51am
Hello pancho_hideboo,
I donot see this source is Cadence analogLib nor in ahdlLib. Any suggestions.
ic_engr
Re: burst source
Reply #5 - Feb 9th, 2010, 5:57am
The followings are general notes.
- Always describe vendor's name which you use as tool or simulator.
- There are many simulators which have analyses called as PSS, PAC and Pnoise.
- Describe in detail with using correct terminologies.
- Warnigns are different from Errors.
- ADS is not name of simulator.
- There is no tool which name is Cadence.
- Don't use Direct Plot of Cadence ADE blindly without knowing definition.
- All gains in Direct Plot of Cadence ADE are "right", "true" and "practical" voltage gain.
- Don't mix up Simulation with Post Processing. They are completely different phase.
- MATLAB are different from Simulink.
- Learn measurements using actual instruments. Not "EDA Tool Play
ic_engr wrote on Feb 9th, 2010, 5:51am:
This source is available in adsLib for Cadence DFII.
If you don't have Agilent RFDE, you have to create custom source by Verilog-A.
I can easily create custom source which realize same function as "VtRF_Pulse" in "adsLib" by Verilog-A.
Burst sinusoidal is no more than ASK or OOK signal.
So if you don't have skill to write custom source by Verilog-A, use combination of vsin, vpulse and multiplier.
« Last Edit: Feb 9th, 2010, 8:14am by pancho_hideboo »
Re: burst source
Reply #6 - Feb 9th, 2010, 6:18am
This is easy enough to do in spectre without needing VerilogA.
  • Create an instance of vsource set to sine, or vsin - e.g. I had frequency 1M, ampl 2
  • Create an instance of vsource set to pulse, or vpulse which is your burst - for example, period 10u, width 5u, rise/fall 1n, low voltage 0, high voltage 1.
  • Create an instance of pvcvsp with number of controlling voltage set to 2, Max coefficent number set to 4, and set Poly Coeff 0-3 to be 0, and Poly Coeff 4 to be 1.
  • Wire all the - pins of the pvcvsp instance to ground, and the + input pins to the two sources - the output pin will be your "burst" sine source.
This works by utilizing spectre's "pvcvs" (polynomial voltage controlled voltage source) - type "spectre -h pvcvs" for more details. The coefficients are chosen so you only get the product of the two input sources.
ic_engr
Re: burst source
Reply #7 - Feb 9th, 2010, 6:20am
Well I do not see adslib, I see rfLib in Cadence dfII.
ic_engr
ic_engr
Re: burst source
Reply #8 - Feb 9th, 2010, 6:21am
Andrew,
Thanks for your input, I will try it.
ic_engr
Re: burst source
Reply #9 - Feb 9th, 2010, 6:22am
adsLib comes with the Agilent tools (e.g. RFDE), and is for Agilent simulators.
If you're using spectre, you can use the suggestion I made previously.
ic_engr
Re: burst source
Reply #10 - Feb 11th, 2010, 4:53am
Andrew,
Thanks you suggestion worked perfectly well with polynomical vcvs.
ic_engr
