This post is substantially same content as your following post.
http://www.designers-guide.org/Forum/YaBB.pl?num=1266065810http://www.designers-guide.org/Forum/YaBB.pl?num=1260351750/5#5The followings are general notes for you.
- Always describe vendor's name which you use as tool or simulator.
Don't do multiple posts which are same content.-
Don't request source code or behavioral model without any efforts.- There are many simulators which have analyses called as PSS, PAC and Pnoise.
- Describe in detail with using correct terminologies.
- Warnigns are different from Errors.
- ADS is not name of simulator.
- There is no tool which name is Cadence.
- Don't use Direct Plot of Cadence ADE blindly without knowing definition.
- All gains in Direct Plot of Cadence ADE are "right", "true" and "practical" voltage gain.
- Don't mix up Simulation with Post Processing. They are completely different phase.
- MATLAB are different from Simulink.
- Learn measurements using actual instruments. Not "EDA Tool Play
