Aug 16th, 2024, 10:24am
oscillator verilog A file code (Read 5600 times)
davidhongkong
Feb 26th, 2010, 1:40am
Hi Anyone,
I am using verilog to do the rf wlan 802.11 g architecture behavior simulation in system level. So far I have difficult time to find a verilog A oscillator code. What I have is osc in ahdl format. So the simulation is not excecutable under verilog enviroment. I am wondering if anyone to help me. Million thanks
Re: oscillator verilog A file code
Reply #1 - Feb 26th, 2010, 5:30am
Did you look at the "Verilog-AMS" link at the top of the page?
Note that Verilog A won't simulate in a Verilog (digital) simulator - you need to use either an analog simulator (such as Cadence's spectre), or a mixed signal simulator (such as Cadence's AMS Designer).
Also, in Cadence's IC tools, you should have libraries (such as ahdlLib, rfLib) which have both SpectreHDL ("ahdl" - no longer supported in spectre) and VerilogA views.
http://www.designers-guide.org/VerilogAMS/
