Jul 19th, 2024, 6:20am
awd calculator (Read 2127 times)
Evgenii
awd calculator
Feb 26th, 2010, 7:35am
Please help! how to  subtract one curve from other curve in awd calculator
I tried next
"display stack"
"wave"
-> click  on a one curve
"minus"
"wave"
-> click  on a second curve,
but buttons "evaluate buffer", "plot", "print" doesn't work...  >:(
ps I need is for evaluating, say, offset voltage
Thanks!  :)
« Last Edit: Feb 27th, 2010, 2:15am by Evgenii »
Re: awd calculator
Reply #1 - Feb 28th, 2010, 5:40am
If the calculator is in Reverse Polish mode (which is the default), you should do:
wave - click on one waveform, then the next
Then hit the "-" key
Then hit plot.
Alternatively you can use the algebraic mode (the choice is in a menu - I can't remember what it's called though, and I'm off line), and use a sequence similar to that you gave. One thing to be aware of is that it is a true algebraic calculator, not a hybrid like many calculators are.
Evgenii
Re: awd calculator
Reply #2 - Mar 1st, 2010, 7:10am
Thanks, Andrew!
