Jul 18th, 2024, 12:35pm
ncelab: *E, CUCFUN (Read 9701 times)
ragudo
Brazil
ncelab: *E, CUCFUN
Feb 26th, 2010, 11:24am
I'm trying to perform a simulation of a VHDL using ams via ADE.
When I netlist and run, the netlist is created correctly, but I get some warnings and this error that I don't know how to solve.
Here are the error messages:
Quote:
ncelab: *N, SFEDPL: Deploying new SFE in analog engine.
ncelab: *W, CUNOUN: Cannot find any unit under teste.ad_ctrl:entity in the design libraries.
ncelab: *E, CUCFUN: instance 'I39' of the unit 'ad_ctrl' is unresolved in 'teste.ad_ctrl_tb:schematic'.
Failed to elaborate ("teste" "ad_ctrl_tb" "config").
If anyone could give me a hint on how to correct it, I would appreciate.
Thanks.
EDIT: I mistyped the errors.
Raphael Agudo
Analog IC Designer
Riad KACED
Swindon, UK
Re: ncelab: *E, CUCFUN
Reply #1 - Feb 28th, 2010, 11:38pm
There could be a multitude of reasons why this error could have occurred. The best for you to start with is looking at the error explanation from ADE -> Simulation -> Output Log -> Error explanation.
Go through the list of proposals to see whether you could spot what's missing in your case.
It looks like the entity for your VHDL has not been found.
How did you create your VHDL ? Using the VHDL editor from ADE or importing VHDL with vhdlin ?
You may check that your VHDL files are well saved in the Cadence database.  This is an example.
In other words, you have to make sure that both your entity and architecture are both under the same cell (That's the rule of thumb I follow).
Say for example I have an 'or' gate.
1. I create, with VHDL editor, a Cell called 'or_gate', view 'entity'.
library ieee, std;
use ieee.std_logic_1164.all;
entity or_gate is
    port(
    in1 : in std_logic;
    in2 : in std_logic;
    out1 : out std_logic
end or_gate;
If compile is succesful, I would be propmted for the symbol to be created (symbol does not exist yet)
2. I create, with VHDL editor, a Cell called 'or_gate', i.e. same cell as previous but with view 'behavior' this time. View 'behavior' is one architecture of entity 'or_gate'.
architecture behavior of or_gate is
begin
    process begin
    out1 <= in1 or in2 after 5 Ns;
    wait on in1,in2;
    end process;
end behavior;
In the HED, I bind cell 'or_gate' to the desired architecture, i.e. 'behavior' in my case and then launch AMS. All should be fine.
If your architecture and entity are under separate Cadence cells, then I'm doubting AMS would work.
Hope this will give you some clues on how to tackle your issue.
BTW, it is good to mention whether you use the Cell-Based 3-step flow or the OSS 1-step irun flow. I am assuming the former as it is default in ADE.
Riad.
Riad KACED
PDK, EDA Support Engineer.
boe
Reply #2 - Mar 1st, 2010, 1:49am
ragudo
Brazil
Reply #3 - Mar 1st, 2010, 1:32pm
Riad,
Thank you for your time.
I had this VHDL from another project, and I just created an entity cell view simply by copying and pasting the code into the VHDL editor.
The problem was that this VHDL had both entity and architecture in the same file, so I followed your example and split the file in two, creating a behavioral cell view and a entity cell view.
I am using the Cell-Based 3-step flow.
After I did this, the simulation completed successfully.
Let me ask you another question, since I have never worked with VHDL before.
Talking with some colleagues, they said that it is usual to have both entity and architecture in the same file.
Is there a way to create a cell view with entity and architecture together and use this cell view?
Thank you again,
Raphael Agudo
Analog IC Designer
Reply #4 - Mar 2nd, 2010, 12:37am
When you create the view, having them both in the same file should cause both views to get created, and it should then work.
Usually I've seen this being a problem when the file was edited outside of Virtuoso - this means that it doesn't trigger compilation and correct view creation.
Riad KACED
Swindon, UK
Reply #5 - Mar 2nd, 2010, 11:02pm
Hi Raphael,
Sorry, I was not really accurate above.
Yes, you definitely can put everything in the same file, it's not a problem at all.
This is for example a code with entity or_gate and 2 architectures of this entity. In Cadence, I create cell 'rkWorkLib'/'or_gate'/'entity' with the following code.
library ieee, std;
entity or_gate is
    port(
    in1 : in std_logic;
    in2 : in std_logic;
end or_gate;
-- 1st architecture
architecture behavior1 of or_gate is
begin
    process begin
    wait on in1,in2;
    end process;
end behavior1;
-- 2nd architecture
architecture behavior2 of or_gate is
begin
    process begin
    out1 <= in1 or in2 after 10 Ns;
    wait on in1,in2;
    end process;
end behavior2;
When Cadence compiles this code, it will create view 'entity' alongside with views for architectures behavior1 and behavior2 + symbol if told to do so:
This is what I got in the CIW when compiled the above code:
Quote:
Updated cellview ... (rkWorkLib or_gate entity)
Updated cellview ... (rkWorkLib or_gate behavior1)
Updated cellview ... (rkWorkLib or_gate behavior2)
Symbol (or_gate symbol) generated and saved in library:rkWorkLib.
regards,
Riad.
Riad KACED
