Jul 19th, 2024, 6:16am
Ocean licences (Read 497 times)
avlsi
singapore
Ocean licences
Mar 04th, 2010, 5:55pm
     Question  1. Can any one confirm me that while running ocean, it takes up the ADE and Spectre licence?
     Question 2: If i use ocean only just to gather the results, which licence does it need?
Thanks in advance.
Winners never Quit,Quitters never Win
Re: Ocean licences
Reply #1 - Mar 5th, 2010, 1:41am
Whenever you use OCEAN, it uses an ADE license. The spectre license is used during simulation - bear in mind that by default spectre runs in "interactive" mode which means that the simulator keeps running, so that doing parametric analysis, or even just calling desVar() to change a parameter and then run() again, it is faster because it doesn't need to re-invoke spectre, re-obtain the license, and re-read the netlist.
You can stop that by doing:
envSetVal("spectre.envOpts" "controlMode" 'string "batch")
but bear in mind this will slow down such sweeps as I describe above.
If you are using OCEAN for post-processing only, it will still use an ADE license (but not a spectre license).
