Jul 19th, 2024, 12:20pm
spectre pz analysis (Read 335 times)
analogrf
spectre pz analysis
Mar 05th, 2010, 11:06am
Im using spectre's pole/zero analysis (using IC5141usr5).
I find the pz analysis to be somewhat less fairly documented. Specifically, could someone tell if the pole zero plot obtained from pz analysis has  any normalization factor on the real axis  ? Also, what does 'constant factor' refer to ? Plz comment.
