analogrf
Im using spectre's pole/zero analysis (using IC5141usr5). I find the pz analysis to be somewhat less fairly documented. Specifically, could someone tell if the pole zero plot obtained from pz analysis has any normalization factor on the real axis ? Also, what does 'constant factor' refer to ? Plz comment.
