Jul 18th, 2024, 8:22am
Ultrasim and Hiearchy Editor (Read 2399 times)
fz2101
Mar 08th, 2010, 9:14am
I'm simulating an oscillator circuit with Ultrasim, when I set what I believe to be the default accuracy in Analog Design Environment by going through Simulations -> Options -> Analog and change the Simulation Mode from the default Mixed Signal (MS, 5) to Analog (A,5), the oscillator oscillates.
However, if I change the sim_mode and speed in Config to the same exact settings, i.e. "a" and "5", the oscillator does not oscillate.  In fact, changing the sim_mode and speed in hiearchy editor seems to have no impact on the accuracy of the simulation.  I used the Ultrasim template when I created the Config view.
Re: Ultrasim and Hiearchy Editor
Reply #1 - Mar 8th, 2010, 2:15pm
Go to Simulation->Options->Analog in ADE (with UltraSim as the simulator) and check "Allow usim_opt on HED".
