Jul 17th, 2024, 10:18am
how to set up a time variable resistor model? (Read 4279 times)
liletian
MD
Mar 08th, 2010, 1:52pm
 Hi All
 Does any of you know how to build a time variable resistor model.
 I used the following verilogA code, but I can not use $time in my code. Does anyone know if there is a way to do it?
 Thank you
// VerilogA for verilogA_lib, res, veriloga
`include "constants.vams"
`include "disciplines.vams"
module res(p,n);
inout p,n;
electrical p,n;
parameter real r=0 from [0:inf);
V(p,n) <+($time+ r)*I(p,n);   Does not work at all
Re: how to set up a time variable resistor model?
Reply #1 - Mar 8th, 2010, 2:00pm
You'd need to use $abstime, not $time. $time is not supported in an analog context (see the LRM; links from the Verilog-AMS link at the top of the page).
liletian
MD
Reply #2 - Mar 9th, 2010, 1:16pm
Andrew Beckett wrote on Mar 8th, 2010, 2:00pm:
thank you very much, it is really helpful.
