Jul 17th, 2024, 10:28am
Increase veriloga simulation accuracy in hspice simulator (Read 2926 times)
neoflash
Mixed-Signal
Designer
Mar 08th, 2010, 2:03pm
I found even if I specify hspice accuracy setting to runlvl=6 and accurate, the waveform from verilogA blocks still look ugly.
Is there any other setting I can use to make verilogA part more accurate?
Neo
patrick
Santa Rosa, CA.
Re: Increase veriloga simulation accuracy in hspice simulator
Reply #1 - Mar 8th, 2010, 4:35pm
Try runlvl=0, i.e. disable runlvl.
Reply #2 - Mar 10th, 2010, 7:15am
You may also want to have a close look at your Verilog-A module:
- does it have continuous/smooth outputs (as a function of the inputs)
- do you have scaling issues (outputs that are huge or tiny compared to the normal scale of voltages and currents)
